Forum: VirtualDJ 8.1 Technical Support
Topic: Cloning and distortion
Everytime I play a song, all of my music sounds distorted and cloned. Distorted with a double beat.
geposted Thu 19 Nov 15 @ 9:00 pm
RobRoyPRO InfinitySenior staffMember since 2012
Check if any filters are active by mistake.
geposted Thu 19 Nov 15 @ 9:06 pm
Most likely you have your sound setup configured wrong, IE, both Master and Headphones sound output is configured to play through the same channels on the same soundcard.
Please verify that you're using the correct sound settings, or post here a screenshot if you don't know how to verify that.
geposted Fri 20 Nov 15 @ 9:53 am
Or maybe there's an fx like Flippin Double switched on as a master effect by mistake?
geposted Fri 20 Nov 15 @ 3:45 pm
