Forum: VirtualDJ 8.1 Technical Support
Topic: Auto Mix Editor - SOLVED
Hey guys,
I have not tried this on my PC yet but on my Mac when I open up the auto mix editor with nothing in auto mix it opens. When I have some songs in my list it crashes every single time. I am assuming that I should be able to have songs in there to edit when they mix yes?
geposted Fri 20 Nov 15 @ 3:02 am
automix not working on pc side either. as soon as its opened it crashes.
geposted Fri 20 Nov 15 @ 3:23 am
ANY use of automix editor under any conditions I've tried so far will cause crash.
geposted Fri 20 Nov 15 @ 3:41 am
Also vdj 8.1 crashes every time every time I use video editor too much...or the combination of any editor... Using windows 7 64 bit 8GBRAM nvidia 2GB all songs and videos are in internal hard drive and everything is up too date! No viruses and clean pc.
geposted Fri 20 Nov 15 @ 3:50 am
Yeap! Same here! automix editor not working
geposted Fri 20 Nov 15 @ 4:05 am
Yep... Automix Editor not working on my system either, guys. Don't think I need to leave my specs since it's happening on a lot of systems.
geposted Fri 20 Nov 15 @ 4:13 am
blckjckPRO InfinityMember since 2008
I have duplicated this as well.
No songs in auto mix, editor opens fine.
One song in list, still opens fine.
Two songs, crash.
The faulting module event viewer reported is ntdll.dll
VDJ version 8.1.2579 on Windows 10 64bit
geposted Fri 20 Nov 15 @ 8:19 am
This has been confirmed, and an update with a fix will be available in the next hour.
UPDATE: build 2582 fixes the problem. To update if you still have the older build, start VirtualDJ, and wait for around one minute for the update to download without playing any song. VirtualDJ should then show the popup saying that a new update is available.
geposted Fri 20 Nov 15 @ 8:24 am
No more crash with 2582.
geposted Fri 20 Nov 15 @ 9:46 am
RobRoyPRO InfinitySenior staffMember since 2012
Confirmed
geposted Fri 20 Nov 15 @ 10:04 am
confirmed ;)
geposted Fri 20 Nov 15 @ 10:51 am
confirmed big time.
I just threw the kitchen sink at this current build (tellyvisuals, tellymedia, milkdrop, videocube, spectral, boom on auto, camera shake, even countdown which isn't for 8!) and then opened video editor and it didn't even blink.
geposted Fri 20 Nov 15 @ 1:26 pm
Wish I would have kept up with the thread. Put 8.0 back on my system yesterday and found that I already missed some of the new features while working last night. Lol.
Thanks VDJ Team for your hard work. :)
geposted Sat 21 Nov 15 @ 3:09 pm
