allowed the 8.1 update on my PC now VDJ won't run grrr
geposted Sat 21 Nov 15 @ 5:34 pm
Please make Sure that there is no VDJ process Running in the background and then try again.
geposted Sat 21 Nov 15 @ 5:41 pm
That didn't help. It was picking up my VDJ7 skin which isn't compatible. I went into registry and changed skin to default and that fixed things. I run both versions but use 7 live.
geposted Sun 22 Nov 15 @ 1:05 pm
can you tell us which skin caused the problem?
geposted Sun 22 Nov 15 @ 1:07 pm
I run both versions, normally I use mixlab 3.1 with version 7 and Mixlab8 with version 8. the update seems to have got these mixed up. so I edited registry to change the skin to virtualDJ 8 skin and the update worked immediately. I'm back to using both versions with the correct skins and everything is fine
geposted Sun 22 Nov 15 @ 4:41 pm
