GeniusDJ suggest songs -a list of song come up only 3/4 of music will play other show Error on deck 1 or 2..when load
geposted Mon 23 Nov 15 @ 4:17 am
are you sure the suggested tracks ( that show Error ) are in you database ?
geposted Mon 23 Nov 15 @ 6:15 am
Not all of these results are local files.
They are suggestions and you need to search them with a Content Unlimited service to get the files to play.
Files that have a simple magnifier next to them are suggestions that you must search for. Sometimes even CU may fail to return results as they are suggestions coming from what other users use to play next.
Files that have a magnifier with a blue line / circle are files that match files you have stored locally on your own computer. These files should load and play right away.
So, please check which files give you an error. If they are files with a simple magnifier and you don't have an active CU subscription, don't expect these results to work.
If you have an active CU subscription, please report back a few titles that can't be found so that we can check.
geposted Mon 23 Nov 15 @ 9:21 am
The Isley Brothers Winter Wonderland this one
geposted Wed 02 Dec 15 @ 11:34 pm
a screenshot of your matches would be interesting.
All matches here played fine.
although the searched track was not found by 100%
geposted Thu 03 Dec 15 @ 7:29 am
Thanks....it work 99.5 of the time I'm good Thank you DJ
geposted Thu 03 Dec 15 @ 11:47 pm
Is it possible to filter GeniusDJ results to show ONLY local results, or to sort them to show all local results first? (sorting by far left "magnifying glass" column seems to resort the results, but not cleanly... )
geposted Sun 04 Dec 16 @ 5:51 am
Bumb this question I would like to know the same?
geposted Fri 26 Jan 18 @ 4:59 am
