Forum: VirtualDJ 8.1 Technical Support
Topic: Issue with Random Video Transition
Hello Team,
I have a small issue with random video transition when the selection
of the video transition stops on Multiadditive random stops working,
I have to select with the mouse or controller a different transition
to return to operate the random video transition
geposted Mon 23 Nov 15 @ 12:51 pm
gggdj wrote :
Hello Team,
I've also have this issue before updating to 8.1
geposted Mon 23 Nov 15 @ 12:53 pm
This is a multi-deck transition, it's not really designed to be used with Random Video Transitions as it makes no use of the video crossfader. I'd recommend for now you set it to Ignore (you can still use it, it just won't be randomly selected) and we'll implement a change so this can work a bit more transparently.
geposted Mon 23 Nov 15 @ 3:36 pm
Ok thanks
geposted Mon 23 Nov 15 @ 6:17 pm
Thanks, great to know...
geposted Mon 23 Nov 15 @ 6:28 pm
