Hello,
I am ready to make the move to 8.1 as my primary software. Although I installed 8 shortly after it was released I have been continuing to use ver 7 and kept my libraries up to date with that version. Now that I am ready to move over is there an easy way to clear out my current ver 8.1 libraries and import my ver 7 libraries into ver 8.1? I am using a Mac.
Thanks,
Tim
Thanks,
Tim
geposted Fri 27 Nov 15 @ 9:40 pm
Just delete database.xml from your VirtualDJ Documents folder and next time you start version 8 it will create a new one based on your current V7 database. Simple as that.
geposted Fri 27 Nov 15 @ 9:55 pm
Delete other database.xml files on other drives too.
You will find them in the Virtual folder in the rootpath of that drive.
geposted Sat 28 Nov 15 @ 3:03 pm
