Forum: VirtualDJ 8.1 Technical Support
Topic: Removing GeinusDJ Tracks from Automix
When I use GeniusDJ to look up songs, if I grab one with the magnifying glass icon with a blue dash on it, and drag it to Automix, how do I remove it from Automix?
With a normal song or video, I right-click it and select Remove, which is one (1) of thirteen (13) different options on the right-click menu.
When I right-click on the song added from GeniusDJ, I see only one (1) option, "Look Up." This now finds all the versions of that song on my hard drive and displays them in the main pane, but does not allow me any option to remove the song from my list.
I've also tried the Delete key on the keyboard, to no avail.
How do I remove it from my list?
geposted Sat 28 Nov 15 @ 10:20 pm
I found a way to "work around" or "kludge" this:
If I select the GeniusDJ song AND select another song/video, I can then right-click the other song/video and select Remove, and both songs are removed.
Of course, now I have to go re-add the other song/video that I just removed.
Seems like a small bug.
geposted Sat 28 Nov 15 @ 10:22 pm
I just did a test about GeniusDJ. Added a song in Automix and I hit delete on the keyboard and it removed it (2586). What version running ?
geposted Sun 29 Nov 15 @ 4:18 am
8.1 on a Mac
geposted Sun 29 Nov 15 @ 10:32 am
I'm on PC. Maybe someone with a Mac can test it out for ya.
geposted Sun 29 Nov 15 @ 2:12 pm
Anyone on a Mac able to test this?
geposted Mon 30 Nov 15 @ 10:51 pm
