I use an extra monitor for searching songs in explorer. It would be very nice if I could double click on a song in explorer and then it would be loaded to the unactive player or some placelist like the automix playlist... Is that possible? Are the comand switches to Virtual DJ for doing this? I have searched for a list of command switches for Virtual DJ but I have not found it...
Best regards
Thomas Lydhig, Sweden
Best regards
geposted Sun 29 Nov 15 @ 7:26 am
You can drag them to a deck ok.
geposted Sun 29 Nov 15 @ 5:43 pm
if you associate mp3 files with the vdj program that might work but it could try and open a new copy of the program each time which would be bad.
geposted Sun 29 Nov 15 @ 5:54 pm
Why use Windows Explorer at all? VDJ has its own browser which is very fast, as it uses the VDJ database.
It is possible to have a separate browser window which can be dragged to a second screen. It does require some change to the skin code but it's not complex.
geposted Sun 29 Nov 15 @ 9:02 pm
There's no switch to send a file from explorer to VirtualDj. You can only drag & drop files to any place you like (decks, playlist, sidelist, e.t.c.)
However you are free to ask for a "switch" on our wishes forum! :)
geposted Mon 30 Nov 15 @ 7:51 am
