I need to use plug -in efect RMX -500 master but not working . I use mixer djm900 card
Thanks sorry for the English
geposted Wed 02 Dec 15 @ 2:01 am
For a master effect to work you need a master channel. If your audio configuration doesn't have one (as would be the case with a DJM) then there is nowhere for a master effect to be applied.
geposted Wed 02 Dec 15 @ 9:09 am
Ok, no way to use it ? Is there any way ? Thank you
geposted Thu 03 Dec 15 @ 2:04 am
