Hello.
I have macbook pro 13'' retina 2014 - El Capitan, Virtual DJ Pro 8 Infinity, Thunderbolt to hdmi adapter.
So my problem is that after several hour of usage, let say playing or automix videos for 5 hours or more and then when i close the program after 5 seconds this message appears on screen '' Virtual DJ 8 quit unexpectedly "
It was the same on Yosemite and also on fresh install of El Capitan. I really don't know, where the problem is.
In this link ''dropbox" I'm sending log file if someone can help me?
https://www.dropbox.com/s/p7g3jeonxug33d7/error%20log%20vdj8.txt?dl=0
Thank you in advance.
geposted Thu 03 Dec 15 @ 7:31 pm
First thing that sticks out to me in the log is the showlogo plugin.
Have you tried disabling the plugin then closing VDJ?
geposted Thu 03 Dec 15 @ 7:36 pm
I tried that and after several hours no problems, I just turn of showlogo8 before quiting the program, will test more.
Thank you very much.
I also have another question but don't have log file.
Sometimes when I'm checking settings I get an error, but don't know what couses it. Is it also showlogo8 plugin maybe?
geposted Fri 04 Dec 15 @ 2:49 pm
Yes, that's a problem with ShowLogo8; I will fix it with an update shortly :)
geposted Fri 04 Dec 15 @ 3:54 pm
I see you have this issue when closing VDJ. Has VDJ literally ever unexpectedly closed on you, while in the middle of a song/video?
geposted Fri 04 Dec 15 @ 8:53 pm
No, never experienced that kind of issue, that VDJ close by itself (knock, knock), but I did find like 3 times when browsing the settings in the middle of my set, that there was an error, not that kind, but like SBDJ said is probably that also plugin related I hope...
When I stop the plugin before quitting the app everything is fine for now :)
geposted Sat 05 Dec 15 @ 6:52 pm
I edited the title of the thread, so it was not so confusing.
geposted Sat 05 Dec 15 @ 10:11 pm
