I'm using a Denon MC6000. When I start up VDJ, the EFX4 on both decks is enabled. How can I fix it so they are not enabled on startup?
geposted Sat 05 Dec 15 @ 11:15 pm
You can add an entry in the on init section of your config, a quick search of the forum should get you the info you want
geposted Mon 07 Dec 15 @ 8:08 am
