Anyone know how to reset the whole browser and all its folders including root folders, iTunes was deleted along with other subfolders. Im using a mac btw.
geposted Sun 06 Dec 15 @ 6:06 pm
You can put them back my adding them back into the browser, however the best way to reset all of your settings is to locate the settings.xml file within the Documents\VirtualDJ folder, and rename it to settings-old.xml (or just delete it.)
Make sure that VDJ is closed when you do this, and when you re-open, you'll see it will be a fresh configuration!
geposted Mon 07 Dec 15 @ 2:19 am
