Topic: Auto Gain, Having some issues
Hi there,
Wondering if someone can help me, I'm new to VDJ 8 from 7. Having some issues with the Auto Gain?
I'm unsure what setting I have to change, for some reason, I have to always adjust the 'Gain' on tracks, and especially when I put tracks on auto mix.
Thanks
geposted Mon 07 Dec 15 @ 2:57 pm
Just use "auto". May be worth rescanning your database to reset the gain levels VDJ has kept in the database since V7.
geposted Mon 07 Dec 15 @ 3:12 pm
Thanks I will give it a go
geposted Mon 07 Dec 15 @ 3:54 pm
I would recommend setting zerodb to -3 or -6
geposted Mon 07 Dec 15 @ 5:48 pm
