Hey everyone,
I DJ from time to times and access to iTunes playlists has been very useful in always having updated playlists and set lists. I also use iTunes for my personal collection and music listening needs. While iTunes is great, does anyone use an alternative software to manage their music/playlists? Is there a cloud solution and syncs offline for use in VDJ or other music software? VLC and Google Play Music for example come to mind. I am looking for a solution however that works well with VDJ.
What do you use?
What do you use?
geposted Mon 07 Dec 15 @ 4:49 pm
Media Monkey is the most common alternative. Almost noting has the playlist flexibility though, unless you go with a competitor's DJ software. But inputting your exact title into Google would have been a better start.
geposted Mon 07 Dec 15 @ 9:44 pm
here's a few others to have a look at
http://www.helium-music-manager.com/ .. paid for versions and free
http://getmusicbee.com/ .......free
http://www.foobar2000.org/ .........free
geposted Tue 08 Dec 15 @ 1:35 am
What do you miss in VirtualDJ's own browser?
geposted Tue 08 Dec 15 @ 5:42 am
Nothing, it's even better than Itunes. But Itunes has integration in almost every DJ-soft. So, every playlist I make in Itunes can be used in every other dj-program and is future-proof!
geposted Tue 08 Dec 15 @ 8:25 am
So it's not possible to export a m3u playlist file from the VDJ browser that is readable universally?
geposted Tue 08 Dec 15 @ 8:28 am
Wasn't there an option in itunes to enable XML playlist sharing? After enabling that option you should be able to see and play your itunes playlists from within VDJ.
Found it:
By default, iTunes 12.2 and later doesn't create an iTunes Library.xml. If you're using OS X Mountain Lion or earlier or a third-party app that uses the XML file, you need to enable Legacy library XML support:
Open iTunes.
From the menu bar at the top of your computer screen, choose iTunes > Preferences.
Click the Advanced tab.
Select "Share iTunes Library XML with other applications."
Found it:
Open iTunes.
geposted Tue 08 Dec 15 @ 1:12 pm
