After about 3 hrs of use in my mac the music starts distorting and goes off i have to restart the program and this fixes it . I bought a new vci thinking it was that but it's not
HELP HELP HELP
I'm use in a 15 in mac book pro ( 6 months old)
Vci 380 ( 1 week old )
HELP HELP HELP
geposted Fri 11 Dec 15 @ 4:00 pm
Here's the questions that I have for you:
What version of VDJ 8.1 are you using?
What OS version are you using?
What other applications are running when you are running VDJ 8.1?
Are you using any VDJ plugins?
What are the specs of the Macbook?
geposted Fri 11 Dec 15 @ 7:23 pm
vdj 8 version 8.1 mac build 2587.1086 and the only plug I I have is the skin by DENyo , BUT IV had that on since 8 came out so its !00% not that
mac book pro 2015 retina 15in
2.2 gig intel i7
16gig memory
not running any other sortware at all .
I was on the new os wich it elcapitan , but yesterday I reverted back to the previous one yosamite to see if that was the cause , but I have 3 friends using the same mac same vci and the new os and non of them are having issues
2.2 gig intel i7
16gig memory
geposted Sat 12 Dec 15 @ 4:22 pm
What Sound Card/controller your using with VDJ-8+ doing your set ?
geposted Mon 14 Dec 15 @ 4:41 pm
please read messages before replying
Vci 380 ( 1 week old ) [/quote]
geposted Mon 14 Dec 15 @ 5:24 pm
Do you get the distortion through headphones? have you tested on other cables/speakers and cable that links mac to controller
geposted Tue 15 Dec 15 @ 1:51 pm
Try refresh your Controller/skin with out close it,I was getting that with VDJ-8 when it 1st came out,I was not using VDJ-8 home skin
geposted Fri 18 Dec 15 @ 2:02 am
