VirtualDJ 8 PRO Infinity does not recognize my JBS Kontrol 3. Config shows JBS-6, not JBS-2. Alltough my licences show Infinity. Do I need another driver?
geposted Sat 12 Dec 15 @ 8:10 am
Please provide the following..
- Screenshot of the Audio tab of VDJ Settings.
- Screenshot of the Controllers tab of VDJ Settings (with the controller selected)
- Content of the Log Report.txt file (read below how to get that)..
Open VirtualDJ, goto Settings->OPTIONs and enable the "Show Advanced Options"
Search for the setting CreateMidiLog and set it to Yes.
Close VirtualDJ, make sure the controller is connected and powered, and launch VirtualDJ.
Once opened, close VirtualDJ again (dont have to check anything else)
Open the Log Report.txt file you will find in /Documents/VirtualDJ folder and paste its content here.
geposted Sat 12 Dec 15 @ 8:54 am
