Please can someone tell me where to select that I want the video to show on a projector screen when i connect to an in house projection system? In 7, in configuration settings, you can see what is connected. Where is this in 8??? Someone said to me that you can see available outputs if you right click on main master video windowbut that doesnt work on mine.....HELP!!! Thanks
geposted Sun 13 Dec 15 @ 11:42 am
On the default skin you can right click the master video preview on the skin (not the actual video window itself).
Even easier is just to drag the video output window to the screen you want to use and double click it :)
geposted Sun 13 Dec 15 @ 12:41 pm
having problems with down loading the plug-in for the logo change, help help help
geposted Wed 16 Dec 15 @ 2:42 am
I'm sorry crystalmarie, but your issue has nothing to do with this subject, which has been reproduced all over the forum. Please start you own thread, thank you.
LOCKED BY AMAHM
LOCKED BY AMAHM
geposted Wed 16 Dec 15 @ 9:54 pm
