Is there any way to lock the info and sideview panes? This was available in VDJ7. It's really irritating that the info pane slides open when I hover too close while pulling songs from my side list. Any help?
geposted Sun 13 Dec 15 @ 7:42 pm
VirtualDJ doesn't even have the feature to hover to open/close the pane... it always requires you to click the header to open or close.
geposted Mon 14 Dec 15 @ 9:02 am
have you tried different skins .
I use the dennyo skin and its fantastic . you can have screens open or closed and they don't do the annoying open thing when you hover on them , have a look
Controller by DennYo
geposted Mon 14 Dec 15 @ 5:27 pm
I'm actually using the Dennyo skin, and having this issue
geposted Tue 15 Dec 15 @ 6:16 am
Any suggestions?
geposted Fri 18 Dec 15 @ 7:42 pm
Switch to the default skin and retest. As Adion said above, there is no hover open feature in VDJ8. If the default skin is doing that, then a video recording would be helpful.
geposted Fri 18 Dec 15 @ 10:42 pm
It will open the Sideview/Split panel if you move over the area/button that toggles the view.
so in the default skin, if you move over the "sideview" vertical button, it will indeed open the window.
geposted Fri 18 Dec 15 @ 11:53 pm
Try this I map some of my keys and controller...
show_splitpanel 'info'
show_splitpanel 'folders'
Show_splitpanel 'sidelist'
file_info
file_info
geposted Sun 20 Dec 15 @ 8:25 am
