In Serato, when you press a hot cue, the song plays until you release the button. In VDJ, it plays automatically. Is there anyway I can re-map the hot cue buttons so they perform like in Serato? I don't want it to automatically play. Using a Pioneer DDJ SX and like VDJ8, but really hate the hot cue differences.
geposted Tue 15 Dec 15 @ 12:25 am
You dont have to remap anything. There is a setting to select the Stutter mode for the Hotcues. Goto Settings->OPTIONS tab and search for the setting "Hotcuemode"
geposted Tue 15 Dec 15 @ 1:40 am
Ahh!!! Thank you SO MUCH!!! Is there that same option in VDJ 7?
geposted Tue 15 Dec 15 @ 3:11 am
I'm guessing that's under the Mapper section?
geposted Tue 15 Dec 15 @ 3:14 am
No. This option exists only in VirtualDj 8
No, it's in options section (enable advanced options view and use the searchbox to find it)
geposted Tue 15 Dec 15 @ 9:46 am
And give this a try, http://www.virtualdj.com/documents/Manuals/VirtualDJ8_User_Guide.pdf
geposted Tue 15 Dec 15 @ 2:18 pm
