I've been trying to troubleshoot an issue with remote connecting. It appears the remote is grabbing my cellular network instead of the wifi network I am on.
I have to switch to airplane mode and turn the wifi on to change the network in the app. After that I have to add the IP directly in VDJ. My iPad running iOS 9.2 detects the correct network, but I still have to enter the ip. I use iTunes and it is up to the latest version, so I would think Bonjour is as well, if this is still being used.
Firewall has vdj allowed and used to work on this setup. Unfortunately, I have not used remote for several months, so I cannot determine what changed.
Any ideas where to start?
VDJ 8.1.2587, VDJRemote8.0.2500, iPhone 6+ IOS 9.2 (Same problem with 9.1)
geposted Thu 17 Dec 15 @ 6:21 am
Same problem here! Any solution? Thanks
geposted Sat 09 Jan 16 @ 3:11 am
