Forum: VirtualDJ 8.1 Technical Support
Topic: Build 2693 and custom icons
djsadimPRO InfinityMember since 2006
After the last update (build 2693) when I open vdj
and I selected the skin that contains custom icons "show default icons.
If you reload the skin then displays the custom icons.
geposted Fri 18 Dec 15 @ 10:41 am
now is ok!!!
thx!!!
geposted Sat 19 Dec 15 @ 12:54 pm
