Forum: VirtualDJ 8.1 Technical Support
Topic: Lyric Downloads
freppaPRO InfinityMember since 2002
Just want to ask where do Vdj take lyrics from ?
Any specific site ?
I tag my mp3 files very serious and there are so many files that doesnt get the correct text.
geposted Sat 19 Dec 15 @ 5:37 pm
geposted Sun 20 Dec 15 @ 7:16 am
Most come from Baidu currently. If you have the original album/single version of the song they usually fit quite well.
geposted Sun 20 Dec 15 @ 7:51 am
Thanks Adion.
I found out where the lyrics gets stored (same spot where the mp3 is located). It's not a regular TXT file so you can't fix it when the LYRICS are wrong.
I had some songs that downloaded the incorrect lyrics.
Now at least we know lyrics downloaded are not from VDJ (2nd question answered from November post).
geposted Sun 20 Dec 15 @ 3:32 pm
Thank You !
geposted Sun 20 Dec 15 @ 7:36 pm
LRC is a common lyrics format, you can open it with a text editor, but you can also find some program designed to edit them.
geposted Mon 21 Dec 15 @ 7:45 am
That was good to know..
Cant find any thing about Baidu, were do I get some more to info about it ?
Im missing the message [download complete] when downloading the text, I dont get any message window at all..
geposted Mon 21 Dec 15 @ 2:38 pm
I use Notepad and looked at the LRC file and it's impossible to edit.
I looked at it with Wordpad and much better, but then again, how can you fix it if the lyric downloaded is wrong (timing for display will be different).
I don't think you can fix it as easy as we want it to be (not practical of fixing it).
I had some songs that lyric downloaded was the wrong one (don't even what song it came from).
Can VDJ read lyrics downloaded with MEDIAMONKEY ? I'm gonna try it.
geposted Mon 21 Dec 15 @ 7:50 pm
