I apologize if this has been asked. I've searched and couldn't find anything.
I'm trying to make the switch from 7 to 8.
In 8...how do you choose which external monitor VDJ outputs to.
For example in my current vdj7 setup, My Hdmi is my secondary monitor, and then I use Air Display as a 3rd monitor. In vdj7 i can choose which one i would like to output to.
I can't find that option in 8, it automatically picks what it wants when you click the video screen.
Any help is appreciated.
Thank you,
Thank you,
geposted Sat 19 Dec 15 @ 9:41 pm
Right-click the video preview screen and select which monitor you want it on.
geposted Sun 20 Dec 15 @ 6:50 am
...i had this problem! It only works if you use the default skin!!
geposted Sun 20 Dec 15 @ 3:23 pm
You can also double-click the video window to make it smaller, then move it to the screen you want, and double-click again to maximize it
geposted Mon 21 Dec 15 @ 7:37 am
