Forum: Addons
Topic: Single Deck - Page: 2
GetGoldPRO InfinityMember since 2017
djdad wrote :
I fail to understand what you are after, but to answer to your question, the skin is using deck 1, so if you need to have it "working" with the DDJ-SZ, you need to use the CH1 on your mixer and Deck 1 on the left side.
DJDAD- I stumbled across this thread looking for an answer on a similar matter. Klaus told me that you could maybe help.
I’m running VDJ on a Mac Mini M2 mounted inside a rolling video booth. I currently have 2 monitors mounted on the top, 1 showing my main DJ screen and the other serving as a mirror to the 55” extended screen on the front.
But I’m looking to better utilize the 2 monitors on top. My controller is a Roland DJ-808, 4 deck. What I’d like to do is have decks 1/3 displayed on monitor 1 and decks 2/4 on monitor 2. Klaus showed he has done something similar using the Blocks skin, but wasn’t sure if having a screen specific to a deck would be possible. What are your thoughts?
geposted 5 days ago @ 10:13 pm
Yes it can be done, all that is needed is a floating window to hold 2 decks and the usual skin window holds the other two, still quite a bit of work even for somebody who can skin [several hours].
Depending on your desired base skin and the changes needed, I might be willing for a price.
I do have a older project that split 1 & 2 to one screen and 3 & 4 to another, it was default pro [can't remember if I also did performance like that too] that could be rearranged fairly quickly.
If interested send me a pm.
geposted 4 days ago @ 10:32 pm
