I would like to be able to export my playlists in a format that is compatible with mixcloud.
    geposted Tue 22 Dec 15 @ 6:26 pm
          I agree, this would be a very useful feature. Mixcloud already allows Traktor and Serato users to import their playlists. An ability to export from the playlist history tab as a Mixcloud compatible 'cue sheet' would do the job.
    geposted Fri 20 May 16 @ 4:04 pm
          VirtualDJ can save a cue sheet along with your mix when recording. Didn't check if it's accepted by mixcloud, but I guess it should be?
    geposted Fri 20 May 16 @ 8:51 pm
The only problem with that is that when you are recording you cannot use tracks that you got from content unlimited or the recording will stop. So I have to use a external recording source in order to record the audio from some of my mixes which does not allow me to use the cue sheet/list function...
(when I am able to record internally the cue sheet/list function works well!)
geposted Sat 21 May 16 @ 2:36 am
          So firstly you're recording content that you don't own, then you're sharing the recording.
Have you not heard of copyright? :-(
geposted Sat 21 May 16 @ 8:55 am
          Available at VirtualDJ 8.2
    geposted Mon 06 Jun 16 @ 12:58 pm
