Hi,
Im new to the forum but have had Virtual DJ for a long time, I am using virtual dj pro7.4 with Hercules RMX controller. I mix vinyl but am considering getting the Timecode Vinyl so I can use some MP3s I have. Can anyone tell me if I need to buy any other software or can I just buy the Virtual DJ Timecoded Vinyl and I can use it straight away please ?
I have Serato Timecoded Vinyl already but cannot seem to get that working as I need to buy the Denon I think...its all very confusing. Ive looked online at you tube vids but still cant work it out....any help would be much appreciated and sorry if this is a boring old question that many have had before.
Thanks
Dean
Thanks
Dean
geposted Wed 23 Dec 15 @ 12:24 pm
You're going to need either a Pro Subscriber or Pro Infinity license to play time code vinyl
http://www.virtualdj.com/products/virtualdj/price.html
geposted Wed 23 Dec 15 @ 12:48 pm
thanks for that...so to be clear before I purchase - if I buy the Pro Infinity and the Virtual DJ Vinyl then I wont need anything else ? would you advise it or shall I buy Serato Denon ?
geposted Wed 23 Dec 15 @ 3:06 pm
You shouldn't need to buy another license if you've already got one (as you say you're using VDJ 7.4 Pro).
You're only registered as an LE user though, so.....
Anyway, there's a setup video on using timecode vinyl with the RMX here -> https://www.youtube.com/watch?v=dp6USvPoZ0k
geposted Wed 23 Dec 15 @ 10:09 pm
You don't have to buy new vinyls. Serato timecode vinyls work perfectly fine too.
geposted Thu 24 Dec 15 @ 9:40 am
