Occasionally , the right-hand deck will not respond once a track has been loaded. The song will not play either using the play button on my Numark N4 ,or the play button on VDJ. The play button will flash red when pressed , but the song will not play. Loading a different track doesn't help. This only ever happens on the right deck , and only happens from time to time. Does anyone have any ideas as to how I can resolve this issue? The only thing I've been able to do is close down VDJ and reload it - hardly practical when working!
geposted Wed 23 Dec 15 @ 5:01 pm
it's because maybe your 10 min is up ? Then after you reload VDj it works again and when 10 min is up, it won't work. (just guessing)
geposted Wed 23 Dec 15 @ 5:13 pm
Thanks for your reply , but no. VDJ is used every night in a bar. Two , three or four nights may pass without this happening. Then , for whatever reason , the deck freezes. The software runs for at least 7 hours each night.
geposted Wed 23 Dec 15 @ 5:35 pm
what license have you got? http://www.virtualdj.com/products/virtualdj/comparison.html
VDJ Home Can't be used for "professional usage" (earning money using VirtualDJ)
geposted Fri 25 Dec 15 @ 10:36 am
Same problem here. Right deck on 2 or 4 deck mode. Controller is sending commands. Play no longer flashing but staying on as if playing on screen and on controller.
Vdj 8 pro license v8.2 b3994
lenovo ideapad810 unmodified
pioneer ddj sb2
pioneer ddj sb2
geposted Sat 30 Dec 17 @ 5:12 am
