Forum: VirtualDJ 8.1 Technical Support
Topic: Tracks only half loading?
Hi there,
I tried to adjust the loading on a track which was 60mins long.
Some reason it won't fully load? Then loading other tracks 4mins long, won't fully load?
Can someone help me out?
Thanks
geposted Sun 27 Dec 15 @ 12:53 pm
blckjckPRO InfinityMember since 2008
Are these tracks in your library or from Content Unlimited / Netsearch?
geposted Mon 28 Dec 15 @ 1:52 am
change and put more of 60 in :
config/options/performance/maxPreloadLength
geposted Mon 28 Dec 15 @ 5:08 am
Be careful how much you increase this on low memory systems.
The default settings should allow the full loading of a 4 min. song.
geposted Mon 28 Dec 15 @ 5:10 am
