Ok Im using this code I got from a thread that Phantom had came up with,
Just map two buttons like this:
toggle 'DeckLeftDual' & toggle 'DeckRightDual'
Then change your jogs to this:
action_deck 1 ? var 'DeckLeftDual' ? deck 1 jogwheel & deck 3 jogwheel : deck 1 jogwheel : action_deck 2 ? var 'DeckRightDual' ? deck 2 jogwheel & deck 4 jogwheel : deck 2 jogwheel : action_deck 3 ? var 'DeckLeftDual' ? deck 3 jogwheel & deck 1 jogwheel : deck 3 jogwheel : action_deck 4 ? var 'DeckRightDual' ? deck 4 jogwheel & deck 2 jogwheel : deck 4 jogwheel
If you want to shorten the code this might work as well:
device_side 'left' ? var 'DeckLeftDual' ? deck 1 jogwheel & deck 3 jogwheel : deck left jogwheel : var 'DeckRightDual' ? deck 2 jogwheel & deck 4 jogwheel : deck right jogwheel
With timecodes I guess you would have to toggle beatlock between deck 1 & 3 for instance and rely on beatlock to catch up...
I haven't tried it but I guess it won't be so smooth as with a jogwheel / touchwheel
PS: The code I posted above also needs to assign the following code on the "touchwheel_touch" command of your controller:
action_deck 1 ? var 'DeckLeftDual' ? deck 1 touchwheel_touch & deck 3 touchwheel_touch : deck 1 touchwheel_touch : action_deck 2 ? var 'DeckRightDual' ? deck 2 touchwheel_touch & deck 4 touchwheel_touch : deck 2 touchwheel_touch : action_deck 3 ? var 'DeckLeftDual' ? deck 3 touchwheel_touch & deck 1 touchwheel_touch : deck 3 touchwheel_touch : action_deck 4 ? var 'DeckRightDual' ? deck 4 touchwheel_touch & deck 2 touchwheel_touch : deck 4 touchwheel_touch
This doesn't seem to work , can someone help me out again please??
Im using a set of Pioneer CDJ 850's.
Thanks for the time and info....
geposted Wed 30 Dec 15 @ 2:07 am
Map one button as ..
toggle '$DeckLeftDual'
and another one as ..
toggle '$DeckRightDual'
map the JOG_WHEEL key as ..
action_deck 1 ? var '$DeckLeftDual' ? deck 1 speedwheel & deck 3 speedwheel : deck 1 speedwheel : action_deck 2 ? var '$DeckRightDual' ? deck 2 speedwheel & deck 4 speedwheel : deck 2 speedwheel : action_deck 3 ? var '$DeckLeftDual' ? deck 3 speedwheel & deck 1 speedwheel : deck 3 speedwheel : action_deck 4 ? var '$DeckRightDual' ? deck 4 speedwheel & deck 2 speedwheel : deck 4 speedwheel
and the JOG_TOUCH as ..
action_deck 1 ? var '$DeckLeftDual' ? deck 1 speedwheel_touch & deck 3 speedwheel_touch : deck 1 speedwheel_touch : action_deck 2 ? var '$DeckRightDual' ? deck 2 speedwheel_touch & deck 4 speedwheel_touch : deck 2 speedwheel_touch : action_deck 3 ? var '$DeckLeftDual' ? deck 3 speedwheel_touch & deck 1 speedwheel_touch : deck 3 speedwheel_touch : action_deck 4 ? var '$DeckRightDual' ? deck 4 speedwheel_touch & deck 2 speedwheel_touch : deck 4 speedwheel_touch
geposted Wed 30 Dec 15 @ 2:34 am
Ok I got it working except I need a script thatll make both decks play when I hit play on my player??
Right now I have the dual deck but when I hit play only 1 deck will play. I think I need a var on the play button that says when in Dual deck mode play both decks when I hit play??
geposted Wed 30 Dec 15 @ 2:38 am
just take any of the above actions and replace e.g. speedwheel with play_pause or whatever action you need to have for a button to work in Dualdeck mode.
geposted Wed 30 Dec 15 @ 2:48 am
Im not following you, lol!! You know if not good at this script stuff, lmao!!
EDIT.
Ok I got it!! THANKS A MILLION!!
EDIT.
geposted Wed 30 Dec 15 @ 2:53 am
