Hello there.
Setting a new computer and hit a bump.. everytime when i open my sampler page vdj restarts it self.. only happens my own pages what i moved from old system.. samples are Mp3 files. Can you see my crash report if system has send one. and figure out what is the problem.
Other strange things is now in Win10 system the vdj folder is installed under \onedrive\files\ should not be any problem but strange..
Eerikki Peltokorpi
Eerikki Peltokorpi
geposted Wed 30 Dec 15 @ 12:54 pm
Ok more problems with this new setup. Seems like vdj doesn't record any settings anywhere because after a crash it everytime find my cdj's and djm and samplerpad as new device and lost its audio configurations and mapper selections. Seems like it has something todo with new folder location under /onedrive/ windows has probably change the policy how and what programs can write to witch folder maybe?? Same as xp -> win7 changed things. AND more random VDJ restarts are now happening.. it doesnt warn or anything it just restart it self.. allways happen when searching a song normaly or changing folder under sampler. very annoying and frustrading problem.. if anybody can advice how to get shits back in order please help me..
geposted Sun 03 Jan 16 @ 9:25 pm
One breakthrue on mission.. Founded that Virtualdj folder under /skydrive/ was completly read-only mode. So that part solved, now my settings are saved.. now let's see if that helps also on that restarting issue at sametime.
geposted Mon 04 Jan 16 @ 6:17 pm
