Is it possible to have a playlist inside of a virtual folder? Tried a test and didn't have any luck. Wanted to make sure I wasn't missing something.
I am trying to break my transition tracks down into manageable groups and would like to have them inside some of my existing folders. Please advise.
geposted Sat 02 Jan 16 @ 11:37 pm
You could try using Filters Folders instead which would then sit very nicely inside Virtual Folders. For example, if you are making a Playlist of say, 2015 Chart Hits (just an example), as long as those words are mentioned somewhere in your File Info, you can create a Filter Folder to find them.
Hope that makes sense to you.
KJ
KJ
geposted Mon 04 Jan 16 @ 12:24 pm
You could create sub-virtual folders inside your virutal folders.
geposted Mon 04 Jan 16 @ 3:19 pm
Used the filter folder option with a comment. Thanks.
geposted Fri 15 Jan 16 @ 11:48 pm
