What is the latest update that is available? I am using VDJ 8 pc build 2770.1092 and I have been expecting VDJ to prompt me to update to the latest build. I have the 'get early access' turned on.
geposted Wed 06 Jan 16 @ 10:21 am
2770 is the latest build.
geposted Wed 06 Jan 16 @ 11:06 am
Thanks PachN, but the reason why I was a little confused is because there seems to be two '2770' updates.
BUILD 2770:
-Fix Japanese and Russian language file crash when trying to create a new account
-Fix issue preventing proper closing of virtualdj when external drive connected during use
BUILD 2770:
-Large performance improvement when scanning songs for bpm etc
-Performance improvement for startup/closing times
-Improve cloud list song searches
-Saving a loop that isn't set on the deck obeys the quantizeLoop setting
-Triggering a saved loop obeys the smart_cue setting
-useKeyFromTag option added to use key stored in tag instead of calculated value
-writing mp4 tags works when no room left at beginning of file
-Fix reading genre tag of WMA tags sometimes containing composer
-Fix lockup when loading an unscanned track with a samplerate higher than the output samplerate
-Fix start of sample being cut off by ramp up
-Fix switching input in Camera plugin
-Fix forced custom controller definitions not being loaded correctly
-Fix potential problem on exit when taskbar notification is visible
-Fix netsearch change in protocol
-Fix potential rare crash on some skins without waveforms
-Touch friendly context menu for covers
-Touch friendly context menu for browser column headers
-Add run time to get_clock tooltip
-Fix will play at times for automix shuffle
-Fix not playing all files in automix shuffle
-Fix rare crash on bad id3 tag
-Fix crash on exit when sending history fails
-Support for single deck skins to load in only 1 deck on double-click
-Preserve aspect ratio of images used in sampler based on letterBoxing setting
-Improved parsing of karaoke tags from filename
-Allow command line opening of songs on windows
-Improve selection of audio only visualisation instance so that settings are correctly used
-Delete .cdg when deleting .mp3
-Remove unplayable results from xiami netsearch results
-Waveform overview fully calculated for streaming songs
-Fix possible crash on mac using maximize/minimize/close actions from controller
-Fix remove played removing currently playing song in automix
-fix potential issue with edit filter folder option on mac
I can remember applying the first update but not the second one and I've been waiting for VDJ to prompt me to update it.
BUILD 2770:
BUILD 2770:
geposted Wed 06 Jan 16 @ 11:29 am
One is the changes compared to the previous early access, the other is the list of changes since the last regular release
geposted Wed 06 Jan 16 @ 12:23 pm
