If I try to copy a file with CTRL pressed and drag&drop, which is already in the destination folder, VDJ will freeze after the message "Do you want to override or skip the file" pops up and choose skip or override.
It does not happen if you do the same operation with the context menu.
I can reproduce that as many times as I want.
geposted Wed 06 Jan 16 @ 9:41 pm
do you d&d the file from a external window into VDJ Browser ?
geposted Wed 06 Jan 16 @ 10:05 pm
v2793 change log it's been fixed.
geposted Thu 07 Jan 16 @ 3:54 am
strange... also with previous 2740 was not able to reproduce ...
geposted Thu 07 Jan 16 @ 8:11 am
This is all getting a bit confusing. According to the changelog there is no 2793 ...... so you must be on an early early release then?
What's the point of having early release software when it's not ......
http://www.virtualdj.com/products/virtualdj/changelog.html?view=advanced
geposted Thu 07 Jan 16 @ 9:09 am
I think the early access is gone and back to Beta mode.
geposted Thu 07 Jan 16 @ 12:46 pm
As I said .... confusing. No consistency at all.
geposted Thu 07 Jan 16 @ 1:05 pm
It is consistent, there is a beta phase, an early access phase and a release.
The beta phase is only available for a small group of beta testers.
geposted Thu 07 Jan 16 @ 1:33 pm
So why are the beta testers telling us about their versions on here. It just causes confusion.
geposted Thu 07 Jan 16 @ 1:49 pm
I agree on that one, I don't know why they do that.
geposted Thu 07 Jan 16 @ 2:43 pm
