Forum: VirtualDJ 8.1 Technical Support
Topic: Shazam Login Problem
ChreecePRO (OEM)Member since 2014
So, i had to re-login in Shazam with a new email, so i signed out, inputed my new email address, then i was prompted to check my email. I went to my browser and logged in gmail, i clicked the link and it says to me that i should click the link from the same browser and deviced i requested access. But that's impossible in the VDJ window.
Is it a bug or am i too blind to see that i am doing something wrong :P ?
geposted Thu 07 Jan 16 @ 8:54 pm
You need to click on the link you got in your Gmail in Chrome.
geposted Thu 07 Jan 16 @ 10:11 pm
As i mentioned above, i clicked the link but i got an error message (see also above). When i go then in VDJ the window keeps refreshing...
There is not much that i can do...
geposted Thu 07 Jan 16 @ 11:13 pm
I've sorted out... I just logged in from Chrome. You must remove the login feature from VDJ because it doesn't work with the current code...
geposted Thu 07 Jan 16 @ 11:21 pm
If logging in by clicking on the link in the email doesn't work. Just copy the Link and paste it in VDJ into the shazam login window.
That way it always works for me.
geposted Fri 08 Jan 16 @ 11:32 am
Shazam changed the page in the VDJ window and you can't paste anything in there...
geposted Fri 08 Jan 16 @ 1:16 pm
RobRoyPRO InfinitySenior staffMember since 2012
confirmed. there is no line to add a link anymore
geposted Fri 08 Jan 16 @ 1:32 pm
I'm experiencing exactly the same after logging out in VDJ and trying to login again.
And it keeps refreshing after deleting shell cookies and restarting VDJ.
geposted Sat 09 Jan 16 @ 12:24 pm
lincol2PRO InfinityMember since 2011
Maybe another video will help? I cannot get on shazam.
geposted Sat 09 Jan 16 @ 4:34 pm
