I use 8.1 on several computers (home, club, and mobile) I have recently switched up my harddrives and I cannot delete the favorite folder i set for my previous harddrives. Please help
geposted Fri 08 Jan 16 @ 5:33 am
Are you on Win?
If so, please check if are able to delete the vFolders with the Explorer. You will find the vFolder on the drive (if the letter is not C) at e.g. D:\VirtualDJ\Folders\nameOfVirtualFolder.xml
If it is your C drive you will find the vFolder at .../Documents/VirtualDJ/Folders/nameOfVirtualFolder.xml
If you are not able to delete the files this way, please check if you are the owner of the file.
geposted Fri 08 Jan 16 @ 11:27 am
