Forum: VirtualDJ 8.1 Technical Support
Topic: Messed up playlist
netblamPRO InfinityMember since 2008
I just updated VDJ. It screwed up all my playlists. It has totally changed the order in which they are save and played. My oldest to my newest playlist is affected. Please tell me there is a solution to this. And I hope I can get a quick response. I can not work with this. I will have to go back to SAM if not. And i do not want to do that. But I need to play.
geposted Sat 09 Jan 16 @ 4:09 am
Right-click any of the column headers and select 'reset sort order'
The reason this happened is probably because you clicked one of the headers to sort it by that header
geposted Sat 09 Jan 16 @ 11:30 am
