Whenever I start VDJ8 and double click a track it ALWAYS loads to deck 2. Is there any way to force it to deck 2? I tried deck 1 select using ONINIT but it overrides it. I also tried a fresh install to see if it was a problem with my settings. Same problem. I have a Pioneer DDj-SB2.
geposted Sun 10 Jan 16 @ 10:00 am
If the DDJ-SB2 is not connected, does the double-click loads the track to Deck 1 ?
geposted Mon 11 Jan 16 @ 7:51 am
It does indeed.
geposted Tue 12 Jan 16 @ 5:30 pm
So what you are saying is that when you launch VirtualDJ 8 with the DDJ-SB2 and no tracks are loaded , the first time you double-click on a track it loads to Deck 2 instead of Deck 1 ??
Can you try again having the default mapping and the default skin selected ?
The only thing that that comes in mind is the key DECK_CHG so instead of ..
action_deck 1 ? deck 1 leftdeck & deck 1 select : action_deck 2 ? deck 2 rightdeck & deck 2 select : action_deck 3 ? deck 3 leftdeck & deck 3 select : action_deck 4 ? deck 4 rightdeck & deck 4 select : nothing
try to assign it as ..
action_deck 1 ? deck 1 leftdeck : action_deck 2 ? deck 2 rightdeck : action_deck 3 ? deck 3 leftdeck : action_deck 4 ? deck 4 rightdeck : nothing
geposted Tue 12 Jan 16 @ 5:40 pm
I tried it with a totally fresh install of VDJ8 and it does the same. Odd.
EDIT: Your mapping works. Looks like you need to sort that out in the next build for the default mapper.
geposted Thu 14 Jan 16 @ 8:53 pm
