I checked the downloads but could not find a mapper for the DDJ SX2. Is there one out there that is half decent?
geposted Mon 11 Jan 16 @ 8:08 pm
There are a couple listed here:
http://www.virtualdj.com/plugins/index.html?category=other
geposted Mon 11 Jan 16 @ 8:17 pm
Arg...sorry ... mind fart. Thanks!
geposted Mon 11 Jan 16 @ 8:20 pm
Just out of curiosity what's wrong with the native mapper and it's not "half-decent" ?
geposted Tue 12 Jan 16 @ 7:05 am
The last 2 builds that i checked the SX2 default mapping after updating the FW on the controller, it was not working for me. The search strip didn't respond and some other difficulties i can't remember now...
geposted Tue 12 Jan 16 @ 3:29 pm
Search strip works. But the deck must not be on air or you must use SHIFT to bypass security.
Take a read on the manual: http://www.virtualdj.com/documents/Pioneer%20DDJ-SX2%20VirtualDJ%20Operation%20Guide.pdf
geposted Tue 12 Jan 16 @ 7:39 pm
The deck i tried was not on air, and as i said there were some more problems, i will check again on friday
geposted Tue 12 Jan 16 @ 7:51 pm
Please feel free to report your issues.
Deck on air means that it's volume fader is open (even if the deck is not playing )
geposted Tue 12 Jan 16 @ 10:41 pm
That's a bit frustrating because some DJs use only the crossfader (I am VDJing and i use the mask transition, so i must use the crossfader) and with this setup we have all the channel volumes always up, so the search strip will never work for us...
geposted Wed 13 Jan 16 @ 3:12 pm
Ok. I will take a look at it then. Any other issue?
geposted Wed 13 Jan 16 @ 3:22 pm
I will report any issues after i check the mapper again on Friday :)
geposted Wed 13 Jan 16 @ 4:00 pm
