im not sure how to go about explaining this, but when I'm using VDJ 8.1 and try to jog through a song to find a spot I want to use on the other deck, my music while either cut out for a second or the sound of it will change. my first thought was something was wrong with my laptop. So far I have ran software to check my hard drive and Intel I5 processor both of them pass the system tests. I've even gone and ran malware and spyware searches on my laptop and get nothing . and as far as space on my hard drive I've used 175 gb out the 688 gb.
I am at a complete loss and have no clue what else i should try to fix my problem?
one thing I have noticed while the VDJ software is running, In the upper left corner you have a CPU icon that goes from green to red. when I move one deck while the other is playing sometimes it will go into the red section and thats when it has issues glitching or cutting out sound. now with that said when i was running my processor check it was pegged in the red and no matter what i did it would cut out at all?
I'd also like to add when I am Djing the only program that is running is VDJ and my laptop is in airplane mode
geposted Fri 15 Jan 16 @ 7:51 pm
"airplane mode" ? Not sure what this mode is about, but your computer needs to be optimized for "high performance" regardless its high specifications.
Take a look at this guide... http://www.virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
A useful tool .. http://www.thesycon.de/deu/latency_check.shtml to check on the cpu/audio spikes.
geposted Fri 15 Jan 16 @ 8:30 pm
The airplane mode is probably just another way of saying "wi-fi is turned off".
geposted Fri 15 Jan 16 @ 11:14 pm
