Forum: VirtualDJ 8.1 Technical Support
Topic: Build 2819 Changelog?
My computer asked me to update to 2819 but the changelog is empty.
Nothing here either .....
geposted Mon 18 Jan 16 @ 3:07 pm
yes same thing here empty change log ... lets hope its something so good they forgot to type it up
geposted Mon 18 Jan 16 @ 3:14 pm
Anyone?
Would be nice to know what's actually in this release before I start using it.
geposted Mon 18 Jan 16 @ 6:22 pm
same here too.Cant find anything
geposted Mon 18 Jan 16 @ 7:00 pm
@Groovin'
Why has your post disappeared?
geposted Mon 18 Jan 16 @ 7:40 pm
maybe we are the guinea pigs
geposted Mon 18 Jan 16 @ 7:44 pm
Who knows what's going on. Pretty bad customer service since this has been live for hours and no-one from Atomix has chimed in yet.
releasing an update to automatically download with a blank changelog is poor.
geposted Mon 18 Jan 16 @ 7:45 pm
I've just looked through and compiled a changelog:
-Fix bpm analysis on samplerate other than 44khz
-Fix default cue colors for controller pads
-Fix import of Serato track colours
-Fix delay when quickly loading songs in a deck other than deck 1
-Fix loading of some cached content unlimited files on mac
-WASAPI exclusive mode initialization improvement
-Fix browser_sort action not reversing sort
- Can select a colour for a cue point in the POI editor
- cue_colour command to get/set cue point colour
- Add colour selection for saved loops
- Add 'loop_color' command to get/set saved loop colour
-Fix database loading issue when drive connected after startup
-Fix deadlock on copying file that already exists in destination using drag&drop
-Scratchwave adjusted for zeroDb setting
geposted Mon 18 Jan 16 @ 8:02 pm
Thank you Scott.
geposted Mon 18 Jan 16 @ 8:05 pm
<<<Can select a colour for a cue point or saved loop in the POI editor>>>
How do I select a color??
geposted Tue 19 Jan 16 @ 5:47 am
Change log should be fixed now
geposted Tue 19 Jan 16 @ 7:08 am
In the POI editor ;)
geposted Tue 19 Jan 16 @ 9:37 am
I looked in the POI Editor, I see no way to change a color. It is probably right before my eyes but I can't see it....
geposted Tue 19 Jan 16 @ 4:39 pm
Don't think it makes any difference at the moment anyway as skins aren't updated for this feature.
geposted Tue 19 Jan 16 @ 4:47 pm
Update: djdad has just stated that this new stuff is NOT for showing coloured cue points over the waveforms!
Apparently that will be coming, but this currently is only for making cue and loop skin BUTTONS coloured.
geposted Tue 19 Jan 16 @ 8:33 pm
What is implemented for now :
- POI/Cue custom colors stored in database (so you can start updating your Music Library)
- Action to read/write a color to a POI (using the action cue_color x for reading, and cue_color x 'color' for setting)
- Ability to color HotCue buttons on a custom skin using <visual type="color" source="">
- Controllers with RGB Leds can use the action cue_color x to display the assigned color of the POI (by default the color follows the deck). The default mapping files will be gradually updated, starting from next build.
What will be implemented in future builds (in our Todo List).
- Songpos, Rhtyhm and Scratchwave elements will offer Colored Cue Markers
- Ability to read/write Cue Colors to Tags
- Updated Default Skins to offer the above mentioned skin elements along with the Hotcue buttons.
- Updated default mapping files for Controllers with RGB Leds (starting from next build).
geposted Tue 19 Jan 16 @ 8:48 pm
Excellent! I can see a lot of users will be wanting this feature added to their favourite skin. Hopefully the authors will be able to cope with demand. :-)
geposted Tue 19 Jan 16 @ 9:49 pm
In my POI Editor I have nothing under CUE. Is it because I am a home user?
geposted Wed 20 Jan 16 @ 1:40 am
Build 2819 is not public yet. So most likely you don't have this build. Once it gets public you will be offered this button as well! :)
geposted Wed 20 Jan 16 @ 1:57 am
I have build 2821.1097...
geposted Wed 20 Jan 16 @ 3:42 am
