Forum: VirtualDJ 8.1 Technical Support
Topic: Removal of "favoritefolder"
I am trying everything possible to remove a favoritefolder but it wont delete. I tried deleting it from within VDJ itself and through the root xml but they still keep appearing. I searched the xml file in the VDJ folder. Anywhere I searched and found favoritefolders in xml including B/Us of xmls I removed the favoritefolder but it just won't go away. Where else would it be?
geposted Mon 18 Jan 16 @ 11:06 pm
x:\Users\username\Documents\VirtualDJ\Folders
not sure if you get these on external drives but you might
geposted Mon 18 Jan 16 @ 11:54 pm
Thank you... That's the 2nd time I forgot where it was.
geposted Tue 19 Jan 16 @ 3:41 am
