Making changes and saving the files in sampler, still not working in Build 2819
<iframe width="420" height="315" src="https://www.youtube.com/embed/Gc3MPyxGxlc" frameborder="0" allowfullscreen></iframe>
geposted Mon 18 Jan 16 @ 11:16 pm
not having that issue in windows
what happens if you hit the disk save icon instead of hitting close button.
on windows the save icon closes the window as well.
geposted Tue 19 Jan 16 @ 12:52 am
Check the video
geposted Tue 19 Jan 16 @ 1:02 am
tayla wrote :
@taliban, to get youtube vids to show on forums delete everything and also include the last forward slash when doing that so you only have the code starting with G and all the letters to the right of it, now make two boxes like this [youtube][/youtube] in between those boxes that is where your code goes with no spaces either side of the inner brackets, you should now be able to see your video.
Thanks but I'm not able to edit that first post again
geposted Tue 19 Jan 16 @ 10:09 am
geposted Tue 19 Jan 16 @ 10:10 am
are your Samples inside a Zip file ?
If not, can you check if the folder that contains your Samples has write (full) permissions ?
geposted Tue 19 Jan 16 @ 6:44 pm
The file isnt zipped nor locked.
geposted Tue 19 Jan 16 @ 11:03 pm
Fixed!!! in 2828.1112
geposted Thu 28 Jan 16 @ 12:03 am
