Hi all,
it's no more possible to save any changes to a sample.
for ex, i want to make a loop with a part of 8beats of a melody but i can't save it.
it's very important because i use a launchpad and need to put some samples..
the Sample editor not working !
thanks ;)
thanks ;)
geposted Mon 25 Jan 16 @ 5:42 pm
If the sample is in a zip file you won't be able to save it.
geposted Mon 25 Jan 16 @ 7:13 pm
the sample isn't in zip file. i tried in .wav and .mp3 but not working...
geposted Tue 26 Jan 16 @ 1:50 pm
You also cannot edit the loop points on a vdjsample at this time.
geposted Tue 26 Jan 16 @ 4:50 pm
Please try again with the newly released build 2827. Its an early access build, so you have to enable the setting earlyAccessUpdates from Settings->OPTIONS (Advanced Options)
geposted Tue 26 Jan 16 @ 5:12 pm
i've already used sample editor for loop saving ;)
geposted Thu 28 Jan 16 @ 12:06 am
You misunderstood what I wrote ;)
Hopefully your issue is resolved in the latest build as stated above.
geposted Thu 28 Jan 16 @ 2:11 pm
oups, sorry bro. yeah thank you guys. resolved with the latest build.great job !!!! have à nice weeknd all :D
geposted Fri 29 Jan 16 @ 3:28 pm
