I dj for an online radio ,I am also a mobile dj.when I have a gig with my dj service I use my controller and theres no issue,but my question is: when I dj for the radio station I just use the computer and no controller,so the headphones are just plugged into the headphone jack of the computer,so I need a way to set everything up so that I can play a track on air,then on the other deck pre listen the next song.is there a configuration that can accomplish this? basically I want to switch from one deck to the other without interfering with song playing on the air.thanks in advance!
geposted Tue 26 Jan 16 @ 4:48 am
You'll need to get a USB sound card to allow you another output to configure for headphones.
You can purchase a more professional style sound card like this, http://www.hercules.com/us/legacy/bdd/p/119/deejay-trim-4-6-scratch-starter-kit/
Or something a little smaller and less expensive, like this, http://www.turtlebeach.com/product-detail/sound-cards-accessories/audio-advantage-amigo-ii/32
Then within VDJ, configure the on board sound card for the master output and the USB device as your headphone output. Should be golden.
geposted Tue 26 Jan 16 @ 3:17 pm
