Hey Folks. I'm kinda new to VDJ8 and am wondering if anyone knows a solution to the problem I'm having.
I use a lot of pre-produced transitions (variable bpm remixes) in my sets to change bpms etc. I have learned how to set Variable bpms and set a 2nd beat anchor in the BPM editor which is the main thing that has convinced me to switch from Traktor. However I like to list my tracks in BPM order and I like my transitions to be tagged as the first BPM in the track. However VDJ seems to be tagging it as the BPM that's in the track the longest. If I go into tag editor and change it to the first bmp it then also changes the bpm of the 2nd beat anchor that I've set up. If i go back into bpm editor and change that anchor it then re-tags the track to the 2nd bpm and so the cycle continues.
I would appreciate any help with this.
Cheers
Cheers
geposted Tue 26 Jan 16 @ 7:08 am
use the notes tag i do stuff like
90 to 138 gradual ungridded
112 to 90 instant gridded
it's the simplest most informative way, it'd be a massive job for the software, only a note for you.
geposted Thu 04 Feb 16 @ 9:19 pm
