Thanks! I'll PM you for an address.
geposted Wed 03 Feb 16 @ 6:57 pm
Was there anything interesting you could discover from the video file? Did it run smoothly and loop seamlessly in VDJ8's sampler on your computer?
If you want, you could test it with VDJ7's clipbank, to see that the file can loop seamlessly.
geposted Fri 05 Feb 16 @ 9:27 am
I did find some issues with the sampler for this clip. Please try if the new early access release improves things.
geposted Sun 07 Feb 16 @ 8:13 am
I'm using version 8.1 2832.1222. I'm sorry to say that I do not see any improvement, neither in playback smoothness, nor in loop seamlessness...
geposted Sun 07 Feb 16 @ 1:51 pm
latest is 2844 :-)
geposted Sun 07 Feb 16 @ 6:20 pm
Right. A question about that: Is there any way to tell the program to update itself, because in spite of having automatic updates and early access enabled, it will almost never do so (popup asking if I want to update)...
geposted Sun 07 Feb 16 @ 6:38 pm
You can't force an update, but you can always manually download it:
http://www.virtualdj.com/download/build.html
geposted Sun 07 Feb 16 @ 7:21 pm
Bookmarked! Thanks, Scott.
Maybe not such a bad idea to put a button in the settings interface to force an update...
geposted Sun 07 Feb 16 @ 7:28 pm
@ Adion: Thank you! Playback is almost - but not quite - smooth! As is the loop: almost seamless, but not quite... Would a bit more tinkering be possible?
geposted Mon 08 Feb 16 @ 9:28 am
I am very happy :)
My looped logo clips flow fluently now, using build 2857...
Thank you very much, Atomix!
geposted Wed 18 May 16 @ 11:27 am
