VDJ8.1 using Behringer CMD DC1 controller. Looking to modify the action of the Load buttons.
Currently loads tracks and turns on pitch_lock. I'd like to change it to turn on pitch_lock for .mp3's but not .mp4's.
I tried...
Deck left (or right) load & file ends with 'mp3' ? pitch_lock on : pitch_lock off
But it won't turn pitch_lock on in any circumstance.
Ideas as to what the correct syntax would be here? Thanks!
I tried...
geposted Wed 27 Jan 16 @ 1:48 pm
param_equal "`get_browsed_song 'extension' & param_uppercase`" "MP3" ? load & pitch_lock on : load & pitch_lock off
That script works BEFORE you load the deck by checking the song in the browser.
Similar result can be achieved after loading the song with this script:
load & param_equal "`get_loaded_song 'extension' & param_uppercase`" "MP3" ? pitch_lock on : pitch_lock off
For several reasons I recommend to use the FIRST way
geposted Wed 27 Jan 16 @ 6:43 pm
Ugh. Both methods loaded the track but neither turned on the pitch_lock.
Because of the 'uppercase' thing maybe?
geposted Wed 27 Jan 16 @ 8:22 pm
No, the uppercase is needed to ensure both .mp3 and .MP3 files are taken into account.
That being said, the script works fine here...
geposted Wed 27 Jan 16 @ 9:35 pm
Did you made an exact copy of the script ? (Copy / Paste) ?
Notice reverse apostrophe on script ( ` ) It's mandatory...
geposted Wed 27 Jan 16 @ 9:37 pm
Oh crap, I was doing the (') thing. I'll try again. Thanks. :-)
geposted Wed 27 Jan 16 @ 9:41 pm
Perfection. Is there anything you guys *don't* know how to do?
Thanks!
Thanks!
geposted Thu 28 Jan 16 @ 12:22 am
