i hoped todays update would fix this.. this and the build previous to it has an annoying "bug" when you move the cursor up or down through the music lists it highlights seemingly every other file. previous builds didnt do this
geposted Thu 28 Jan 16 @ 1:23 am
A pic of what I mean
geposted Thu 28 Jan 16 @ 2:47 am
geposted Thu 28 Jan 16 @ 4:29 am
Cant reproduce it.
Can you provide exact steps ? What are you using to select/focus folders and tracks ? Any specific script actions ?
Is this skin related ? Can you reproduce with the default skin ?
geposted Thu 28 Jan 16 @ 2:15 pm
djdad wrote :
Cant reproduce it.
I am having the same issue on this early access build! This is weird. I'll tell you the steps. i use the mouse and go up and down, not the scroller. It automatically highlights some songs. Sometimes they are highlighted for a second. And sometimes longer....This is weird.
geposted Thu 28 Jan 16 @ 4:00 pm
A little bit more info.... It does it on all skins. Even on the default. But the default skin has grey colour you dont see it that much but its there. I am using fruity v8 where its kinda black and you can see it clearly. As soon as you use the scroller the songs get unmarked.
geposted Thu 28 Jan 16 @ 4:03 pm
It appears that the bug is present when i use the DarkMinimal skin
We are investigating
Ok managed to reproduce and reported to Team.
geposted Thu 28 Jan 16 @ 4:20 pm
It happens on all skins. Its just that at the dark one you can see easier. I am using fruity v8 and i see it.
geposted Thu 28 Jan 16 @ 4:54 pm
I dont know how i didn't see this before but it is happening even with the public build. Confirmed it on 2 Laptops. 1 Windows 7 64 Bit. 1 Windows 10 64 Bit.
geposted Thu 28 Jan 16 @ 5:22 pm
Yes, it's an issue in the current public build too.
geposted Thu 28 Jan 16 @ 6:07 pm
present in public and beta
geposted Thu 28 Jan 16 @ 10:11 pm
You mean earlyAccess?
Yes, we are aware. The problem has been identified and a fix is being tested.
geposted Fri 29 Jan 16 @ 12:55 am
Is that the same bug I reported earlier?
geposted Fri 29 Jan 16 @ 11:46 am
Using default skin. Are you talking lightly highlighting each song as you scroll through? I can't seem to duplicate what Maxx pictured.
geposted Sat 30 Jan 16 @ 1:11 am
If you went through the comments you would see that it has nothing to do with scrolling. Go back and read the comments again. I've confirmed it on 10 PCs with pro licence
geposted Sat 30 Jan 16 @ 1:17 am
Thats OK guys , you dont have to provide further details nor debate ;)
The bug has been found and fixed for the next build
geposted Sat 30 Jan 16 @ 4:31 am
Great news!!! Any news on the video editor crash fix?
geposted Sat 30 Jan 16 @ 4:39 am
