Hey guys so i recently have bought virtual dj 8 and a brand new controller ( G2V ) and i can't figure out how to get the music to play through my headphones, however its plays through my speakers but i need to be able to hear the next track before i can do a smooth transition. so i shouldn't need a sound card right since the headphone jack is built in my g2v.
thanks PTE
thanks PTE
geposted Sun 31 Jan 16 @ 8:15 am
Have you been here http://geminisound.com/product/g2v and downloaded the manual etc. and studied it?
I would assume that the manual tells you how to set things up...
geposted Sun 31 Jan 16 @ 9:49 am
sure have read it and i still can't find out how =/
geposted Sun 31 Jan 16 @ 9:01 pm
how about a screen shoot of your audio config
geposted Mon 01 Feb 16 @ 12:32 am
OK I have just downloaded the manual and had a look - it's really not very helpful regarding VDJ settings!
Does VDJ 8 not recognise the G2V and offer a default config for it?
If not, you need to use a master & headphones config, with the G2V audio channels set to 1&2 for master and 3&4 for headphones. This is usually how similar controllers are configured, so it's the most likely option.
geposted Mon 01 Feb 16 @ 7:11 pm
