hi this isnt working - i have set it to YES so that it shows below the middle list of tracks on screen but its not showing at all ??
geposted Sun 31 Jan 16 @ 6:56 pm
Did you restart VDJ? This particular option doesn't take immediate effect.
geposted Sun 31 Jan 16 @ 7:08 pm
Actually all you need to do is reload the skin, I can't think of a reason why v8 can't do this automatically when this option is changed.
geposted Sun 31 Jan 16 @ 7:34 pm
on V8 default skin, the software has to be relaunched/ skin changed or refreshed that the changes are visible ( like display horizontal sidelist )
geposted Sun 31 Jan 16 @ 9:26 pm
